V1702 /V2003T ENGINE SWAP COOLING FANS
ICEMAN59
BOBCAT
Apr 5, 2024
WHAT IS THE DUEL ELEC. FAN KIT MODEL NUMBER UPGRADE FOR A V1702 / V2003T ENGINE SWAP
5,214
Are you asking what dual fan kit do you need for your bobcat?
First what bobcat are you working with, more of a curiosity thing as I converted my 743 from a V1702 to a V2203 and I used the stock flywheel fan and have had zero issues with over heat in quite a few years or use.
Are you trying to eliminate the flywheel fan?
ICEMAN59
BOBCAT
Apr 5, 2024
I'M WORKING ON A 1992 743B SKID-STEER . THE OEM FAN IS NOT ENOUGH FLOW. HAD TO USE A DIFFERNET STYLE BELL HOUSING. LIMITS FLOW. SOME ONE HAD POSTED THE FAN KIT PART NUMBER. I CANT FIND IT NOW. DOH
5,214
Please stop typing in all caps, that Internet rude as it's yelling.
I don't know why you had to use a different bellhousing as the V2003 should have fit the stock housing, yes with a little modification to the bolt holes.
I don't know of anyone on this forum that posted anything about a dual fan kit for a bobcat.
You can get dual fan kits off ebay or amazon, there was never a stock option for an electric fan kit for these units.
You might try Skidsteerforum.com
ICEMAN59
BOBCAT
Apr 5, 2024
SORRY. I'M HANDICAP AND CANNOT WORD UPPER / LOWER CASE ..
