Using 3 point snowblower for ballast
trashcanman
Street, MD
I am purchasing a new (old stock) BX 2370 this week with a mid mount mower, fel, and 3 point snowblower. For minor fel work, would the snowblower be ok to use for rear ballast, or would I be better of buying a ballast box? The snowblower weighs 400 pounds. Thanks for any input.
2,871
That would be plenty of weight for sure,, however the size might get you into trouble in some tight spots. You can make up a ballast box out of a plastic 55 gallon drum, or a ply wood box anything,, That will keep the physical size down smaller then the blower size.if that makes any sense. Look around in the search and there is a ton of ballast posts, I used a bottom half of a plastic 55 gallon drum, and I think 5 bags of ready mix. Never had a problem
Mike.O
B2650
Mar 28, 2017
109
CT
Agree with Skeets.
I have my backhoe off and in the shop. I threw the 6' York rake (guessing 250LB) on the back of mine for some light loader work. It is a real pain having something that wide behind you all the time. I can't tell you how much bark I've ripped off trees on my trails :D:D.
Definitely do a ballast box. Plus I don't mind banging around my York rake, its much more rugged (and cheaper) in relation to a blower. I would sure hate to go banging around an expensive snow blower.
vic gerbasi
M110 L3300
Feb 19, 2016
232
dugald mb canada
On my L3300 I use the snowblower for ballast all winter as I move large square bales of hay approx. 800 lbs has worked well this way for years
