TSC post hole digger
Rigger Dave
L3301
Nov 11, 2016
25
Camden, NC
Getting ready to put in some fencing to make a pasture for goats and a couple of cows. Figure right around 300 holes or so. Not doing them by hand! Wanted to get some thoughts on the tsc post hole digger. Don't want to spend to much but don't want it to break 25 holes in. It has pretty decent reviews on the website, but I'd like to hear your all's opinion.
Thanks in advance,
Caboose
B2650HST
Aug 16, 2016
80
Washington State
Ive put in between 150-200 holes with mine and I have been very pleased. I think the biggest variable is the makeup of your ground. My ground is virtually rock-free and very sandy - near a river and probably old river bottom from before the days of the earthen dikes in the area. In other words, about as easy as it gets for a post-hole digger to perform in.
- I have never augered in and had to break out a pipe wrench and breaker bar to get unstuck. That likely has most to do with the ground quality, but also I am careful to dig a little then clear the hole.
- I have used almost exclusively a 9" auger. I bough a 12" which worked well on a couple of holes and I would expect it would work well considering my ground is very workable.
- It is a little clanky, but I think that is just typical of that type of PHD and not truly indicative of the County Line quality. A Land Pride may be built a bit tighter, but for the price, I don't think there's enough of a difference. That being said, I only have used the County Line PHD from TSC.
- I did consider buying a Land Pride PHD, but if I had it to do over again, I wouldn't hesitate to buy the County Line again.
Ground quality is everything. If your ground quality is dicey (e.g. lots of big rocks, clay, gumbo, buried cars, etc.), you might have a different experience than I have had. But, I think that would hold true for just about any PHD in this class. They will never perform the same as a front-mounted, hydraulic, reversible PHD. If you have these types of ground conditions, you will have to go slow and careful, BUT it will beat the hell out of digging them by hand.
My $.02
PS - running mine on a B2650.
Dean
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
I drilled a couple hundred holes with my store brand phd that I bought either at tractor supply, or central tractor 20 years ago. There is really not a lot to go wrong with a phd construction wise. I recall having to replace the auger tip after 100 holes, but that interval would be entirely associated with soil type, rocks, etc.
6,355
Dave, what kind of post are you going to use, and what soil conditions do you have? If you're using anything but wood I would not bore holes, drive them in. If your plan is wood, might consider T post or pipe on the "back" side. Quicker, easier to get in place.
Rigger Dave
L3301
Nov 11, 2016
25
Camden, NC
Thanks for the replies guys. Digger ordered. My soil is old farm land. Sandy loam and then a big sand ridge below that. Don't anticipate any issues with the digging except some roots here and there. Will pick it up at the store on Saturday. With military discount, won't be too bad.
D2Cat,
I'm doing a combination of wood and and metal. Wood where we can see it from the house (not built yet) and wire for the back side behind the pole barn. The fence will tie in to existing perimeter wire fence. Just need to keep in about 4 goats and a Dexter cow or two.
Dr Honda
BX1870
Mar 30, 2015
174
Pitt, PA
I have one. Works well. The soil around here in PA is rocky. It will catch once in a while, but I just bump the clutch a few times, and it would break free. Oh... and with my small tractor, I had to move the pivot pin back and forth between 2 of the holes. One to get my auger out of the ground for transport... the other was for better "Break-Out" power. Yes... it was some work, but better than doing them by hand.
