Has anyone used TSC Majic Paint in the gallon can and how did it work for you?
I got a gallon of their gray primer, a gallon of the orange, their hardener and their thinner.
Let me start by saying that I am not a body or paint man.
I sand blasted the fenders, dash and hood/bonnet. I then etched everything. Applied two coats of primer, wet sanding between each coat and waited 3 - 4 days between coats. First coat of orange, 4 days then wet sanded before final coat. Added hardener to final coat. (put on with a brush)
Results:
Drying time is horrible. Painted boom pole as described above. after final coat I left it inside for 5 days then in the sun for 4 more days. The first time I used it some of the paint easily came off. The hood, after almost a month to harden, after the last coat, still scratches easily even with the hardliner added. (Sprayed on) The dash after 2 months still scratches easily.
The quality of my work is far from perfect but I expected much better results. I followed their directions exactly.
Curious if you have used their paint and what the results were?
Results:
