Trying to help my brother.
gktilton
79 B7100 w/ FEL, Deere 261 Finish Mwr, Woods M4 Bush Hg, Potato Plow, Cultivator
May 5, 2010
230
Hooksett, NH
He has a different brand tractor with a 15hp diesel.
We ripped the engine apart due to non start and low compression.
Rings were junk, he is being told $150.00 per cylinder for rings. Is this typical, or is he getting screwed?
gurn
Kubota L175
Apr 15, 2011
239
12
Nashville,Tn
Is that for a ring job or just the rings? Seems high to me compared to what Kubota rings cost. What brand tractor,Rolls-Royce? :D
gktilton
May 5, 2010
230
Hooksett, NH
Its a Satoh with a Mitsubishi KE70. And that is for just the rings, we can do all the labor ourselves. Total cost for rings, bearings, and head gasket was just about 500.00, seems impossible to me.
gktilton
May 5, 2010
230
Hooksett, NH
Hoping so, we are considering measuring the pistons and cylinders and trying to find rings that we think will do instead. Everything inside this engine looks perfect except the rings are practically missing they are so worn. The cylinders look and measure great and just needed a small carbon ring cut off them, don't really need to even hone them.
Just looking for parts advice that won't cost him a fortune for what should be a small cheap part.
gktilton
May 5, 2010
230
Hooksett, NH
He has only found one source so far, and they guy just says that's the price nothing to do about it.
cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Mar 27, 2011
341
80
Pemberton NJ USA
Here is a supplier with some Satoh Mitsubishi parts including rings, Maybe your model is shown, Prices here seem reasonable.
http://www.stevenstractor.com/parts/compacts/mitsubishi-satoh/engine-parts.html
Here is a Yahoo group that is dedicated to Mitsubishi Satoh Tractors. They may have some parts source info.
http://mitsubishi-satoh-tractor.info/
Here is some more parts links
http://www.satohparts.com/parts.html
http://www.satohparts.com/satoh_us.html
http://www.ssbtractor.com/tractors.cgi?m=mitsubishi
Company History
http://www.satohparts.com/tech.html
I found the below name and phone number of an individual who indicated that he had rings and pistons in stock for some Satohs
http://smallimporttractor.com/
Smallimporttractor
503-628-6319
Hope this helps:cool:
gktilton
May 5, 2010
230
Hooksett, NH
Thanks, I had found those since we started this search. Only 1 had the rings and it was the same $150.00 per cylinder + Shipping.
He is going to take a piston and the old rings to a local engine shop and see if they can recommend or manufacture something for him. Otherwise its $300.00 for just the rings for this rebuild. Yikes.
gktilton
May 5, 2010
230
Hooksett, NH
Thanks for all the suggestions, he found a place and got the rings for 150 for both cylinders. Hopefully putting it together next weekend.
gktilton
May 5, 2010
230
Hooksett, NH
A little late getting back to this one but my brother did get the part and while I was in Maine this weekend we put it together. Took about 8 bleedings of the lines before it would fire but after that it started at first turn of the key. Hooked up the tiller and turned about 1000 square feet of sod into topsoil in no time. He says it never had power like this before. Thanks for the help. :D
