Trencher for B7100
torch
Jun 10, 2016
2,595
839
Muskoka, Ont.
I've come across this Kubota-brand trencher for a B7100. The 3ph and PTO cover has to be removed, and this gets bolted on in place. The lift cylinder gets piped to the outlet under the seat. A drive sprocket goes directly on the PTO shaft.
Does anyone have any idea what the model number would be? I'd like to check out the parts website to see if repair parts are still available.
and here is a Video clip of trencher operating
5,152
Everyone knows that's a BK7A trencher. :p :D :cool:
That's the first time I've seen one!
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
565
169
Herald Calif.
Hello
This was a popular trencher 40 years ago. You must have the creeper transmission installed to use it on the B7100. The creeper transmission was dealer installed. The normal ground speed of the B7100 is to fast for a trencher.
Lance
5,152
Hello
Lance
I'm curious as the only ones I've ever seen were on a B7100D and this one looks like it's on a B7100HST.
And like lance said The b7100D needed a creeper gear box on them, would it still need the creeper gear setup on an HST?
Dunbar
L2501 LA525 QA PFL2042 Forks RCR1860 FDR1672 BB1560 EA55 WR Grapple FitRite TnT
Aug 2, 2018
215
I vote for coolest post of the day.
Are their modern equivalents of this trencher? It's probably better to rent a trencher, like the excavator vs BH* * debate. Probably won't work with a quick hitch. I hope the OP puts it to work and posts pics.
4,402
It is an odd setup. The metal shield that has the KUBOTA decal would typically be a flexible rubber (like a heavy mud flap) and flop down to the teeth. Also most trenchers have a "crumber" which functions as a shield of sorts and spring loaded plate to scrape the crumbs left in the ditch.
torch
Jun 10, 2016
2,595
839
Muskoka, Ont.
Apparently it's the first time Kubota Canada has seen one too. At least, its not among their on-line parts lists or owner's manuals. Maybe it's considered a grey-market model from the States up here :p However, I did find a parts list for it on the Messik's site and there are several manuals being advertised on eBay. So parts could be an issue and notably missing even from the Messik 's listing is the actual chain that cuts the trench! Kind of an important bit.
I don't think it will fit my B7100 without removing or modifying my cab. I found one set of photos where someone has modified one to fit a 3ph. I'm not sure how well that would work. Did Kubota design it to replace the 3ph so as to apply sufficient weight on the implement?
I wasn't looking for one, just came across it. I thought it might be handy occasionally. But the owner is asking $900, and it will require modification to mount and even then it might not work. So I'm sitting on the fence right now -- interested, but not motivated.
SidecarFlip
Banned
548
Looks like a big chainsaw to me.....:eek: Last time I laid waterline that had to go deeper than my single point ripper with the pipe attachment would go, I went to Black Swamp rentals and rented a self propelled trencher for the afternoon. If I remember correctly it cost a hundred bucks.
shootem604
Apr 23, 2018
875
British Columbia
Is it a "built by" or "built for" Kubota implement? Very cool though!
