Tractor not being used for 3 weeks
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
323
102
St. Louis, mo.
Mid Missouri is getting drenched in rain so my b2601 will probably be barned for three weeks . Should I start it and let engine warm up every couple of days or just leave it alone. Have owned it for a year but has never been setting for more than a couple of days with out playing, I mean working .My heart tells me to start it but that's probably to make me feel better not the kubota
Jay in Massachusetts
BX2670 with mower, loader, snowblower
Dec 25, 2017
20
Westhampton, MA
I've let tractors sit for weeks and sometimes months at a time, and, if the battery is charged, they will almost invariably start.
There are many stories about old tractors sitting out in the field for YEARS, and with a little fresh fuel and a fresh battery, will start right up (sometimes accompanied by wasp nests blowing out the muffler).
So I would say, probably not at issue for your machine.
Blkvoodoo
B2400, LA352, RC60, Cammond Box Blade
Mar 27, 2010
141
Zebulon NC
Mine sat from Oct thru to Feb unused, decided to swap the loader on and mower off as we were expecting snow. Little beast hit right off on a 20° day rearing to get out and work. I was impressed.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
I wouldn't worry. Probably does more harm starting it and not getting it right up to operating temp.
If anything get a battery tender for it and plug it in.
Mine sits all the time and I don't have a tender on it. No issues at all. And it gets down to minus 40 degrees here.
hodge
Nov 19, 2010
2,860
371
Love, VA
No. It won't hurt it to sit for that amount of time. 3 months would be different, but not 3 weeks.
It doesn't hurt the tractor, itself, to sit for long periods without running. What does get hurt is fuel that sits for long periods- keep the tank full so that you don't get sweating/moisture; and keeping the battery charged. You can run it for about 20 minutes or so to charge the battery, or simply put a trickle charger on it. You also want to keep an eye out for rodent nesting.
Otherwise, the tractor doesn't know if it's been a day, or 6 months, since it last ran.
rentthis
998
21
summerville,sc
I have a Case trencher with a Kubota Diesel engine. It sat on my back lot for 5 years. I put a battery in it and it started. Same fuel and all. I considered it to be a miracle. I don't suggest you try 5 years but 3 weeks should never be a problem. If it makes you more comfortable, start it once in a while. if you don't, your only concern should be a low battery.
4,659
Mine will sit for couple months at a time before being started and used.
rut3556
L2250, TG1860
Oct 23, 2015
112
15
NH, USA
>>I've let tractors sit for weeks and sometimes months at a time, and, if the battery is charged, they will almost invariably start.<<
Yup, same on this end. ;)
quazz
L3800 and Z411
Jan 6, 2014
296
Rockley, NS
All of my seasonal equipment, mower, chainsaw, motorcycles, trimmers, power washers etc sit for all of the winter months and outside of fuel stablizer and a battery tender (I try to rotate through) everything fires up at it should. Three weeks is nothing. The tractor probably gets more use in winter so it rarely sits that long but I wouldn't think twice about it if it did.
