towing capacity for B7300
ar.223
KY
Hello, I pick up a nice used B7300 tractor a few weeks ago for some small yard work and inside our barns work. Plan on pulling trailers every now and then. Being a use unit, I don't have a owners manual for specs and hoping someone who had one can tell me what can it tow.
5,180
Capacity is in the range of 2200lbs.
Tongue weight should be less than 600lbs.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,131
933
Williamstown Ontario Canada
You cannot get a better answer to your specific question than from Wolfman!!
In case you don't know about Kubotabooks.com, sometimes you can find free operators manuals and Work shop manuals.
http://kubotabooks.com/AutoIndex/
I looked and did not see a B7300 but there are others close to that model, at least in number, like a B8200.
It is worth a look, if not for this tractor, then for another model.
Dave M7040
HiPowerOne
B7300HSD,LA271,RCK60-24, Bush Hog SQ480, Pronovost Puma-54,Winco 10KW PTO GenSet
Jul 19, 2019
23
Shoreham, VT
Sorry, a bit late chiming in, but I was searching B7300 posts and found this...Wolfman is correct...my B7300 owner manual says trailer weight 2210 lb max and tongue 660 lbs max...also lower link end max loading 660 lbs.
2,852
I figure when you run out of traction thats enough
jvanvleet
B7300, LA271 loader
Oct 4, 2011
Fargo, ND
Late to the party as I don't stop by here often. If you PM me your email address I can get you the owner's manual.
