Tiller size question
bmwmike
B7100, 1640A loader, tiller, box blade, grader blade, carry all. John deere 455,
Jan 13, 2013
79
clarksville, Tn.
I have a 60"tiller that I use behind a large tractor, and I have some land about 90 miles away from the farm that I want to put some food plots on.
I don't want to haul a 7000 lb tractor that far, so my question is can I take the out side tines off and make this about a 50" tiller and use it behind my B7100?
Does anyone see any problems doing this? I don't want to buy a smaller tiller for the two times a year that I will be doing this.
mike
DocGP
117
SE TX
Shoot, put it on your little tractor and try it like it is. I bet it will work fine. If anything, take shallower bites.
Doc
ShaunBlake
Dec 21, 2014
899
I have a 60"tiller that I use behind a large tractor ...
That will work.
That is the best approach!
The B-series tractors' tillers (I tend to focus on B6100s) I've read about are as wide as or wider than the tread width -- 60" or more. I believe some have a little trouble at 72", but they make it work.
Load the tires, and get lots of weight on the front end, then let 'er rip!
bmwmike
Jan 13, 2013
79
clarksville, Tn.
Thanks Guys, for the advise.
I think I will haul it over there as is and try it , but take the tools to remove the tines if needed. That way it should work one way or the other.
mike
