Tightening Loader Bucket Bolts?
MattN03
2011 B3200, LA504 FEL w/B2366 SSQA conversion, BH76 BH, EA Wicked 55
Sep 5, 2016
222
40
KY
I picked up this 2011 B3200 a few months back and many of the loader bolts retaining the cylinders are half way backed off. After 40 hours or so that I've put on the tractor, they don't appear to have backed off any more. Should I tighten the nuts back down or are they this way from the factory?
07wingnut
258
106
Clearwater, BC, CA
The nuts appear to be lock nuts so there is no danger of them backing off the bolt. All the bolts do is hold the pin in place and keep it from rotating. So leaving as is, or tightening both work.
MattN03
Sep 5, 2016
222
40
KY
Yea, it looks like a nyloc nut. I was wondering if I tightened them down if that would help with some vibration & noise?
luketratts
L2600DT FEL
Jul 26, 2016
35
Gold Coast, Australia
I had the same issue, I put a washer on and tightened, at least that way you can easily monitor if the become loose.
I check all mounting bolts for FEL and ROPS regularly cause they do work loose.
OldeEnglish
Jul 13, 2014
766
Western, MA
It wouldn't hurt to put new lock nuts on them or lock washers. Like said before they are just keeper bolts holding the pins in place. The will do nothing for vibration, just keep all of your pins well greased.
scdeerslayer
MX5200DT
May 23, 2016
434
SC
Most likely been that way since new. I know on mine those came from the dealer fairly loose. Like said they are really just a retaining pin, not really necessary for them to be tightened down.
rentthis
1,009
25
summerville,sc
When I buy a new machine, I use a hammer and chisel to foul a couple of the threads so the nut can't back off. I have had that happen and cause all kinds of problems. If I have to remove the bolt, I cut it off and replace it. Since I rent the machines, I am never the one operating the machine and don't get to keep an eye on them. A couple of whacks on the bolt and you never have to wonder.
lugbolt
ZG127S-54
Oct 15, 2015
5,393
2,087
Mid, South, USA
They're supposed to be a little loose-the assembly manual specified I think 1/4" between the nut and the pin boss on most of them. I never questioned why. I suspect it has to do with not crushing the pin boss down-even slightly-which would make the pin tough to remove when the time comes.
