Hi folks,
I just picked up an old Kubota... an L200... my first tractor in the 20hp+ range. I'd like to tap into the hydraulics on this rig, so I can run remote stuff... a wood splitter, a live top link, maybe even a loader eventually... so I'm trying to learn how to do this.
This model has a hydraulic pump on the front of the diesel engine, and the hydraulic reservoir is built into the front part of the fuel tank. Hard lines run from the pump & tank, back to a single valve located under the right side of the operator's seat. In the operator's manual I've got, it talks about tapping into the plug in the top of this valve to get hydraulic fluid for remotes, but it doesn't talk about where to tap into the return line.
One guy I've emailed with said that the hydraulic system on this tractor is an metric standard that the Japanese got from the English... and I'd need to find the correct pressure T, fittings, etc... but he didn't give specifics, and now he's on vacation for three weeks(!)...
So, I'm wondering if anyone has worked on the hydraulics of these older L-series Kubotas, and knows what standard they are and where to buy parts.
Below is a picture of the valve in question. The return line doesn't actually come out of the valve itself, it comes out of the housing next to it, which is the housing for the 3pt hitch lift cylinder. The high-pressure feed line from the pump enters this valve on the under side, you can't see it in this pic. The front of the tractor is to the right in this picture.
Thanks in advance, for any help!
-Norm.
-Norm.
![](http://www.forestryforum.com/gallery/albums/userpics/15714/kubota_l200_valve1.jpg)
![](http://www.forestryforum.com/gallery/albums/userpics/15714/kubota_l200_1.jpg)
