Strange Transmission issue BX25D
Franceco
BX25
Jun 29, 2016
Portland
Good morning,
I have a strange issue with my 1-year-old BX25D,
While driving downhill on a gravel road in 2WD, if I release the accelerator and slowly start to break, just before the tractor stop completely , 1 of the back tire, start to oscillating back and forth.
This oscillation cannot be stop by breaking, it can only be stop by accelerating. Even by powering the tractor off, the oscillation will continue until I reach the bottom of the hill.
It doesn’t happen in 4WD
Also maybe part of the same issues, I try to drive the tractor on a asphalt road, in 2WD it also do some small oscillation, you can feel the back of the tractor oscillation left and right.
Is this normal , or there is something wrong with my transmission ?
maclean
BX25D
Jun 25, 2014
242
Lowell, Or
Sounds like the liquid ballast in the tires.
Only in 2wd or also in 4?
When was the last time you checked the lug nut torque?
-Mac
Franceco
BX25
Jun 29, 2016
Portland
Hi Marc,
thank you for getting back to me
What do you mean liquid ballast ?
it only happen on 2WD, hohewer i will do some more test tonight.
i never check the lug nut torque, the tractor have barely 50h of operation, i will check it also tonight.
Francesco
5,180
Check tire pressure, they are know for having and running on flat tires! ;)
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
Hi Marc,
Francesco
Liquid ballast is when you add a non freezing liquid to fill the tires for extra weight.
Chances are you do not have it since you questioned the function.
Ray
Grouse Feathers
Feb 16, 2015
1,022
Lovells, Mi
You didn't say how steep the hill was. It sounds like you are losing traction and one wheel is sliding on the rough gravel. On steeper downhills you need to use 4wd.
Tooljunkie
May 13, 2014
4,150
27
Like the back end of tractor is swaying side to side?
Or a slight up down? If i drive my L1501 on cement or hard pack ground it does a little wobble. I know most tractor tires arent perfectly round, may be a tire pressure issue. Easy place to start. Some like to over-inflate the tires. Check your manual.
CountryBumkin
Sep 27, 2015
568
Central FL
Ray
He might well have liquid ballast and not know it.
My new BX2370 had water filled rear tires and I didn't know it. The Dealer added it because I have a FEL, but never mentioned it, and I didn't ask. It wasn't until I removed the rear tires to add wheel spacers that I discovered it.
