"Try this test. Shift into PTO speed #1, and then start the tractor leaving the transmission in neutral. Ease out the clutch, and see if the PTO turns."
When I start the tractor the PTO turns with the clutch pressed. When I release the clutch the PTO turns and turns. I tried to engage the PTO with the clucth pressed and with a little grinding it works(not in #3 only in #1). But when I press it again the PTO won't stop.
"Turn tractor off. Keep PTO speed #1 selected, put tractor in first gear, select range #1. Start tractor, and release clutch."
Done that. The same thing with the PTO but now the tractor is moving. Nothing else wrong. I think.
"Keep doing these tests thru each gear, range and PTO speed. It will tell me if you have a gear issue with the PTO, or a transmission main shaft gear issue. Record your info and report back!"
Done that. The same thing in all gears and ranges with the PTO. In #2 and #4 the clutch works fine and the PTO stops when I press it.
Another problem that could be related to this is that when in gear, when I engage the lever for reverse in FORWARD or REVERSE for the first time(the tractor not moving) it grinds a little - 3 or 4 times and the lever is shaking(even with the clutch pressed for more seconds). Should I readjust the clutch?
Thank You!
