Well it has really been some time since I last posted in this forum. My tractor (1979 L245DT) has been running great for quite some time. Last I used it was about a month ago. I was pushing dirt around the yard, not pushing much really. I was just letting it run for a bit while digging by had and it stalled. I hadn't fuelled up in a while so I just assumed it had run out of diesel. Today I attempted to start it and every time I try, it will start, run for a second or two and then stall. Even if I start it and apply full throttle, it runs just as long, but at full throttle. It seems to turn over ok, not hard or anything. I checked all the fluids, which seem fine. I just finished changing the cylinder head gasket last winter so Im really hoping it is not something big that will require a lot of tear down. It does need a rewire, but it has been working perfectly up until this point. I got lots of good advice from the members on this site when I did my head gasket so Im really hoping some of you will chime in with some thoughts on this.
Thanks in advance.
Thanks in advance.
