Shuttle Shift Agravation
E/S
2009 M8540HDC 4x4 w/ Cab
Jan 6, 2010
251
Reno, NV
My M8540 HDC has developed a problem at less than 1 year old and 175 hrs on it.
When using the hydraulic shuttle shift a lot doing loader work it suddenly will not engage, leaving it at a dead stop. I have changed gears, direction and range with no results. The dealer is checking into it but I am looking for ideas, got any suggestions ?
E/S
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,115
Hardisty, Alberta
There is a couple of bulletins on the Hyd shuttle on M8540 tractors but yours should be new enough that they wouldn't apply. Kubota will likely replace the shuttle valve, they don't repair them during the warranty period, and that will likely fix the problem!
Ed
KubotaTech
None- I get to play with everyone elses stuff
Apr 1, 2010
185
PA
Check to see if the clutch cable is still hooked in moves the control valve spool correctly. Check the shuttle cable as well. Does the tractor drive if it is put in 4wd? Does the PTO work?
E/S
Jan 6, 2010
251
Reno, NV
Ed
Thanks
E/S
E/S
Jan 6, 2010
251
Reno, NV
I operate in 4wd 90 % of the time, haven't had it in 2wd when it occurs.
The PTO does work.
E/S
KubotaTech
Apr 1, 2010
185
PA
If it suddenly happens when it is warmed up, I also think it would prob. be something with the shuttle control valve.
