Shutting down
Swampcollie
Mx5800, la1065 loader, rcf2772 mower, blade, disc
Aug 19, 2016
Sedalia, mot
really appreciate this forum and all you folks on it.
I have an MX5800 I purchased new last summer. My previous tractor was a 50+ yr old gas jd. I always throttled that tractor down when shutting it down because it backfired if I didnt.
Should I be throttling down prior to shut down or does it matter? DPF is what makes me wonder.
Thanks
2,215
On a non DPF - most cut off after a little slow down, I typically allow the engine to idle for 30 seconds or so - then cut off.
NOW on a dpf, I would imagine the game is a lot different......SheepFarmer, or others who have been in the DPF world will know the scoop on this !
5,288
Yes, you should idle it down then shut it down. ;)
TripleR
Sep 16, 2011
1,911
SE Missouri
With our turbo tractors, we idle down and let the turbo etc. cool down for a couple of minutes if it has been working hard, or do a slow roll to the barn if it is some distance away.
virginiavenom
373
12
Sherman, TX
yeah, if it had a turbo, let the turbo spool down and idle for a little bit, just like 30 seconds or so if you were just pushing the tractor. my 4060 I turn down to idle, give it about 5 seconds then kill it, then I release hydraulic pressures.
sheepfarmer
Nov 14, 2014
4,445
663
MidMichigan
Each of the new tractors seems to have slightly different starting and shutting down directions, depending on engine design and whether or not tnere is a turbo. Generally shutdown is from idle. Check your owner's manual for how long to idle. The dpf will not be adversely affected at the end of work by a couple minutes of idling, the exhaust is already pretty hot.
Swampcollie
Aug 19, 2016
Sedalia, mot
Thanks, sheepfarmer.
Thought I had read the manual carefully, but guess I missed that. Gonna reread.
