Renting a trailer for a L2501
Pote
23
'Murica
It'll be rare that I need to tow the tractor, but I'd like to know if anyone rents a trailer by the day (U-haul, etc) to move the tractor vs. buying a decent trailer, then licensing it, then insuring it, etc. I get a utility trailer for about $30 when I need to move the side by side, but I think the tractor is too big for a 6x12 u-haul. Any other options and size suggestions? I can put the box blade in the back of the F250 so it would just be the 2501 and the loader.
4,425
Re: Renting a trailer for a 2501L
Call you local rental yard. The ones that rent every tool you can think of. They'll probably have something you can rent by the day, three days, or week.
Poohbear
Jul 6, 2018
472
133
Gilmer,Tx,United States
Most rental yards have trailers & Uhaul has car haulers that would work. No buddies with a trailer ?
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
U-Hauls car haulers, are open center floors. They might work depending on the track width of the machine. Those are only like $60-$70/day or so. Tie down/load securement points, might be a little difficult to do correctly, since they use a proprietary built in system.
U-Hauls open utility trailers (they all have sides), have tail gates that are narrower than the width of the actual trailer floor. I asked why this was, and it's because people would rent them since they are cheaper than the car haulers, and then load cars on them. Their fix was to make the tail gate narrow.
When I bought my B8200, I used an enclosed double door U-Haul trailer, and some car ramps to drive it into the trailer.:D Worked pretty good, not ideal, but it worked. No ROPS on that machine BTW.
Couple "First Place Rentals" (same type of place the D2Cat mentioned) around, that rent trailers of varying capacities, for $100/day or so.
shiraz627
BX23S Piranha toothbar, Underarmor, PFL1242 pallet forks, BXpanded thumb, ripper
Aug 1, 2018
206
Kingsland. GA
I called the local equipment rental place and they don't rent trailers. :(
SidecarFlip
Banned
548
U-all has tandem axle open bed trailers with surge brakes. I've used them before. Should be fine for your tractor. Not sure if they have a ramp but any hill will work.
Gillie Dog
L2501 HST, FEL, Forks Attachment, Harrow Disc, etc.
Dec 12, 2018
79
Southern California
Yep to heavy.
What does it weigh?
Our tractor is (yours might vary by how it is set up)
L2501D HST = 2623
L525 = 805
Filled rear tires= 480
10 gallons diesel = 70
So our tractor weighs 4,000 lbs :eek:
GD
troverman
Jun 9, 2015
1,188
268
NH
U-haul's largest open trailer is a two-axle 6x12. That easily accommodates the width of your tractor but I think 12 feet would be not enough for the length of the tractor and loader. The U-haul trailer has sides on it including on the front. They list a max payload of just over 2600lbs. That's likely not quite enough for your tractor.
Realistically, if you were to buy a trailer, you would need a tandem-axle trailer with at least 3500lb axles under it. The minimum length I would go for is 16' but preferably even longer to help accommodate 3-point attachments. I understand your reluctance to buy a trailer for the couple of times a year you might need to move your machine. Perhaps a place that sells trailers would be willing to rent you one. Home Depot rents trailers, but I think only small ones.
4,425
I hauled an L3250 a few hundred miles in a stock trailer. I just removed the upward pointed exhaust. It pulled nice, being a gooseneck.
SmallChange
B6200D
Jun 14, 2018
25
Port Deposit, MD
What about hiring a car carrier to do the job? That doesn't require owning or renting a trailer, or having a towing capability on your own vehicle. And there are zillions of these available for hire. They probably can get into more spots than trailers, too.
I've been wondering about this for the occasional remote task. Does it turn out to be much more expensive?
troverman
Jun 9, 2015
1,188
268
NH
It's a reasonable idea, and they certainly will do it, but it seems like it always costs an arm and a leg.
vic gerbasi
M110 L3300
Feb 19, 2016
232
dugald mb canada
maybe try a neighbour, friend and pay him to haul it for you
Pote
23
'Murica
I'd be towing >50 miles each way. Hiring a rollback would be sweet, but $300 per trip aint gonna cut it. Calling a couple of Herc/Sun Belt shops sounds like my best move.
