I'm starting a new thread as my previous one was more panic and questions than progress. I have finally started to get some work done so I'm hoping to gain the interest of others who may be willing to lend an opinion on some issues I have. I titled it "refurbish" as its not an entire rebuild as others here have done.
The tractor is an L245DT with serial #51417 manufactured in 1979. Nice little tractor. The couple I got it from used it only to plow/grade their laneway. They got it from its original owner. It came only with the rear balde, and what looks like a kick off valve in the cab. Has never had a loader on it.
I got the tractor in the spring. Got it off the trailer and it got stuck in reverse so i had to have the 1st and reverse shift forks replaced. Sign of things to come I guess. After that I noted some issues surrounding the oil. Firstly, I noticed oil was getting blown all over the right side of the engine and cab. There was oil around the head cover, and also around the gear case, but I was unable to determine exactly where it was coming from as it was being blown every where by the fan. I also noted oil weeping around the oil pan. Lastly upon removing the coolant, oil was found there too. This of course is distressing. There was only a small amount as I didn't even notice it until it had time to settle in the pail. The first thing I did was pull off the head cover. The gasket was in poor condition, but the frost plugs are intact.
The next logical step is the head gasket. So last night I finally got the head off, which was a pain in the butt. I had to put a ratchet strap across the heat sheild in front of the fuel tank and through the cab just for the head to clear it. I didn't find any shims along with the gasket. Not sure if this is unusual or not. That being said I'm nervous about reassembly in regard to clearances. The shop manual says to insert soft lead wire through tone of the injectors and measure it flattened for tolerances. Deal with that when I get to it. Ive never really torn into an engine this much before so I'm really looking forward to the opinion of others from the community here. Let me know what you all think.
Sent from my Dell Streak using Tapatalk
