T Todd W Mason New member Equipment 2015 Kubota L4701DT 4x4 gear drive,Land Pride 1872 cutter Jul 8, 2015 6 0 0 USA Nov 20, 2015 #1 how do i adjust the rear tire and wheel for max width on L4701DT tires are14.9-24-R1 Last edited: Nov 20, 2015
Bulldog Well-known member Equipment M 9000 DTC, L 3000 DT Mar 30, 2010 5,440 75 48 Rocky Face, Georgia Dec 11, 2015 #2 Should be different mounting tabs on the outer rim where it bolts to the center wheel disc. It will allow the wheel to be set in or out. If you move them after a few hrs of use be sure you re-torque them.
