Rear Blades - Which Brand ??
tk1469
147
North Central Michigan
I suspect that there are numerous other threads out there on this subject - but I'm going to ask it again. My apologizes...
I'm looking for a rear (back) blade for my L3800 that will be used to clean up snow - along with my FEL. I'm looking for a 7 ft blade that is GOOD QUALITY that is in the price range of about $500 to $600. Tilt capability is not crucial - nor is off-set features - but it would be nice to have them.
Based upon what you're using now - what would you recommend ??
Thanks.
meanjean
Kubota MX4700
Aug 10, 2010
922
Hazelridge, Manitoba
The heavier, the better!
Don't undervalue the off set feature, real handy to have.
Also look for a blade which spins 360 degrees.
Pick a blade which allows you to reverse and replace the cutting edge.
I like my King Kutter!
bunchgrass
Deary, Idaho
Gotta disagree with the King Kutter blade. I have an 84" one and the design is not good - example, the pin to set the blade angle is ends up with it being easily bent (and thus stuck). Also - the welds broke etc (all while plowing snow). I'd go with "ya get what ya pay for" - look at LandPride.
Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
Dec 25, 2010
953
Kellogg, Idaho
Although mine is smaller then what you are looking for, I like my Land Pride :)
bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
Sep 6, 2011
579
27
Ventura Ca
dont forget to get on your computer and go to Craigslist I founf several used implements thru them good luck ...Dan
TripleR
Sep 16, 2011
1,911
SE Missouri
We have gone through some blades and will now only go with Woods, Landpride or Rhino.
Marty394
L3010 w/ Cab, RCR 1560, RB 1584, SMC Loader, KK II 60" Gear Drive Tiller
Feb 28, 2010
86
Wisconsin
I've had a Land Pride RB1584 for 3 years without any problems. I use it for snow removal and grading a gravel road. I have to admit that there have been times that I wished I had the offset feature and occasionally the tilt feature. When removing snow from a gravel road with deep ditches, it would be nice to be a little further away from the edge of the shoulder!!!!
Bob
asbug
B7001 - looks orange to me... Woods 5' scrape, 42" rotary cutter, shreader/chip.
Feb 11, 2011
155
Varnell,GA - USA
I have a woods 60" and love it. The B7001 can handle it and since I have no downpressure the weight of the unit is all the bite I have.
Mine is old, but looks great and has all I need but off set capability. Pis are good and strong and it spins all around and tilts off of horizontal.
KC
