question about B9200 and B2150 fuel tanks.
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
Leafy England....
hi all, i am about to construct an 2nd indepdant aux hydraulic setup on my non hst B8200.
My project involves the fitting of many parts of which one is a new oil reservoir.
From my intial findings the B8200, B9200 and b2150 share many similar parts if not the same, but having part numbers is not allways enough on a custom build.
I was thinking of using a fuel tank from a 9200 or 2150 since the chassis layout is very similar and the same inmmany respects from the rear of the tractor.
on the 9200 and 2150 the fuel tank is mounted behind the seat, now based on the fact that the dimesions around this area on all 3 machines is pretty well identical i am hoping a fuel tank will fit my 8200.
what would be really good at this point would be some dimensions of a 9200 / 2150 fuel tank along with any bracket that hold it to the chassis and connections point on the tank.
any feedback on this would be greatly received.
rob
Marek Spectra
Kubota L1-22 Loader BF 300, Ford9N+BenHur G-518
Aug 5, 2012
Poland
helo again :)
I have a second Kubota B2150 HST :). He is currently under renovation. what size you need? Fuel tank is out of the tractor. I do photo and specify the dimensions.
Rob
Nov 22, 2009
679
Leafy England....
thanks for the reply.
I require the sizes of the fuel tank (L x W x H) if possible also what the connections are on the tank.
Is it held on by straps, if so what do they afix too.
many thanks.
PS, glad you got your loader information.:)
rob
Rob
Nov 22, 2009
679
Leafy England....
many thanks for information and picture, that is just what i needed.:cool:
rob
