Pulled the trigger on used L3400HST
Gundoctor
Kubota M7040 4x4/ BX2230 4x4/ JD MX 8/ Ford 101 Moldboard 3 bottom Plows -
Well for Easter I now have a 2007 L3400 HST with 213 hrs.. The R-4 Tires are loaded and has a LA463 Loader. It has 4 rear remotes box which has a Hydraulic Top Link and a Hydraulic RH side link as you will see in photos. Came with a Meteor 60" Snow Blower ,Woods 72" Rear Blade and Woods 65" Box Blade. The owner was moving and had to sell it. Walk into a great deal.
I will have to make some changes down the road - kind of "semi-Wildfire" if I can. Paul is the best.
Time for Easter lunch now.
David Pidgeon
New Haven, Vermont
pmhowe
L4240, Ford 8N, Kioti CK 2610
Jun 23, 2012
117
Banner Elk NC
Hi David,
That tractor looks beautiful. You will love it - especially the HST. I envy you the implements - wish I had the snow blower. Happy Easter!
Phil
Wildfire
Holy smoke David you did good! It's a beauty! Good shape too. Lucky you. Thanks for your kind words ;)
So what's planned for the beast! It don't look like it needs much.
Congrats. Enjoyed seeing it. Thanks or posting.
Paul
hodge
Nov 19, 2010
2,861
373
Love, VA
Nice tractor, doc. And it is all set up to play. Nice find.
Gundoctor
Paul:
I have to change the piping on the 4 valve Prince Block. He pipe it direct to the block so there is no way to take the hydraulic cylinders off. (see photo below)I will put some Pioneer hydraulic tips and adapters on.
Then I need to change the snow blower chute rotation from manual over to hydraulic rotation.
That is just for starters for now.
David Pidgeon
New Haven, Vermont
TripleR
Sep 16, 2011
1,911
SE Missouri
You made out like a bandit on that one, nice tractor with good features and equipment. Wildfire can set you up with a Vehicle Stabilization System, blind-spot sensors, strobes, chaff tubes, collision avoidance system, on board compressor system...:)
