Power Service Fuel Treatment?
TiftTyson
2018 L2501 HST, LA 525 Loader, Landpride Rotary Cutter, Box Blades;Bush Hog Til
Mar 24, 2018
19
ATHENS, GA
I run Power Service Diesel treatment in my Ford Superduty. It boost cetane and adds lubricant needed for injectors. Is anyone running this product or similar product in their tractor? Any reason not to?
billrigsby
Mar 17, 2015
1,034
213
Florissant CO USA 8213'
www.facebook.com
I use it, we have always used it at all my work(s) in ALL diesels,
(anti-gel properties) and have had no fuel issues in three winters,
see no need not too, but no expert!
:D
RonBoyBX25D
B2650, LP Grapple, Bro-Tek spacers, QH, Box Blade, Landscape Rake, RB, and 1560G
Aug 1, 2015
477
Minneapolis, MN
Have used it for 4 years in my BX, no fuel issues or starting issues in the winter.
6,378
It’s what I use. Silver bottle in summer, white in winter.
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
This.....
I have been following the above for the last 3 years with my L4600 and all is well to date.
To me cheap insurance and I got the idea from OTT 3 years ago when I purchased my tractor.
4,534
Been using it for a dozen years. Never had fuel related issue in my tractors or truck.
Well, I did have one "issue" with my Kubota fuel. Lent tractor to neighbor and he thought he was being "neighborly" when he refilled it with gas. :mad:
Ring3
B2150, B3030, loader and hoe
Apr 9, 2018
Wheeling WV
Use it in all my diesel equipment. Have for years. Never any issues. Cheap insurance. I swear I notice better performance using it in the Chevy.
2003 Chevy Duramax
1996 Kubota B2150
2008 Kubota B3030
Others that have come and gone
Rob
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Biggest thing I've ever seen is mixing it to strong. These engine are very small compared to most diesels and will overheat with to much conditioner.
dalola
BX2380 w/FEL & Woods RM48 RFM, Yazoo/Kees Max2 ZTR
Jun 30, 2017
316
I think it's pretty cheap "insurance" when you consider what could happen, if you had fuel issues. Certainly not to say adding a product guarantees you won't have fuel issues, but I'm betting it lessons your chances dramatically.
Btw, I use Stanadyne products, just because I like their reputation & history with diesel engines. I think any reputable brand should work as advertised.
I also use Seafoam in all my small gas engines for the same reasons.
TiftTyson
Mar 24, 2018
19
ATHENS, GA
I added to my past two refuels. Thanks for the help.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,455
469
Used to run it in my class 8 trucks, diesel pickup and tractor, until I discovered I got better results from Howes.
dalola
Jun 30, 2017
316
If you want to see how well the product that you use is rated compared to other products on the market, read this report.
Both power service and Howe's do a poorer job of adding lubricity than just using a dose of 2 stroke oil.
http://www.jatonkam35s.com/DeuceTechnicalManuals/Diesel_fuel_additive_test.pdf
Interesting report. I would think, even tho that was 10 years ago, the results probably wouldn't change much.
Will certainly be switching over to the Opti-Lube, as it appears to be a superior product.
Thanks for posting.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,455
469
I saw that report. All I know is Howes unstuck two injectors in my 6.0 Powerstroke when nothing else did.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,455
469
Here's the problem with reports and internet reviews:
My washing machine died so I just bought a cheap one on the spot. Then read the reviews online. Said it was the noisiest worst junk ever.
Started to panic thinking I just blew it. So tried it. It is dead silent and does a better job than the expensive one I had.
Then I bought the highest rated tires for my F350. Were the worst tires I ever ran for traction and wear.
LOL.
