Pat's easy hitch for a Mx5100
tater pop
64
Maud texas usa
I just ordered a pat's quick hitch for my MX5100,or there any tricks that I need to know about them? I do know for me changing post hole digger and bush hogs is a chore .
SidecarFlip
Banned
548
Thought about getting a Cat 2 set but instead I just bought a second tractor.:D
johnjk
Apr 13, 2017
1,286
883
West Mansfield, OH
Installation is super easy. I put a set on my B3200 in place of my quick attach from HF. A lot less noise now with Pat's. The HF unit is now on my brother in law's green tractor. One thing to do that many have mentioned if you have multiple attachments. Take a Sharpie out with you and mark the spreader bar for each attachment. This way you can set it to the proper width prior to backing in for a hook up.
Technically, your implements will sit a few inches further back than they would without the hitch. PTO shaft geometry should not change that much but be aware.
mendonsy
B7500HST/LA302
May 28, 2012
339
19
Mendon, NY
You might also need a longer top link. The Kubota top links tend to be a little bit short, but the generic top links from TSC work fine with the Pat's QH.
Jblac197
L3800, bush hog, tiller snowblower
Aug 21, 2018
73
Hibbing
U have pats also and they are definitely a timesaver. The only thing I would say is buy some grade 8 bolts instead of using the ones it comes with.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
tater pop
64
Maud texas usa
Thanks great idea!!
tater pop
64
Maud texas usa
After I installed it I put a 6 foot howse heavy duty shredder to it. Me being a tight wad I used old hitch 7/16 pins and after running for about 4 hours I lost a pin and I can say they are tuff because their was no damage to the easy hitch. I sure like it,I thing my shredder did a better job set back just a bit.
les.smith99
B7800
Jul 27, 2010
45
Tyler, Texas
You will love them, I have 2 Kubota’s each has a set, they make putting on implements easy.
Mike9
Kubota B6200
Oct 9, 2015
391
31
Ghent, NY
I had to buy a longer top link for several of my attachments. Otherwise they were a great investment - those and @Hodge's telescoping stabilizers. I also bought a PTO extender because the steel box the ROPS is welded too can be a real PITA to hook up.
les.smith99
B7800
Jul 27, 2010
45
Tyler, Texas
Just follow the instructions, I have heard some suggest replacing the bolts with grade 5 or 8. There is a U-bolt on each one that holds the back end down. I would suggest that once you them secured with double nuts cut off the extra exposed threads. They caused me some problems, cut off they don’t.
