Opinions on converting deck to Mulching?
cogset
BX 2670-1
Apr 16, 2016
Falmouth, Maine
Hi,
New here though I read a lot of posts before buying my BX (2670-1) last year. I mowed one season so far about 3 acres using a 60" mid mount deck with grass catcher and also blew snow last winter (though it was mild winter in Maine).
I am considering converting to a mulching setup and understand Kubota has a kit which under-deck baffling and a door for the exhaust port.
Questions:
  • How much did you slow down ground speed when mulching?
  • What did you (or did you not) like about the mulching setup?
  • What blades did you use? (original, Kubota, Gator, other?)
  • any other issues or concerns?
Thanks in advance,
Peter G.
Dr Honda
BX1870
Mar 30, 2015
174
Pitt, PA
As far as I know... the real mulching kit is only available for the fine cut decks.
With that said... did you have a problem with your standard deck leaving visible clippings? Mine cuts clean, and broadcasts them out where I don't see anything.
Personally... I would take the bagger off, and just see how it works. I only put a bag on my tractor for fall leaves.
Oh... and how do you blow snow with your MMM ??? (LOL)
