Oil Light on an L1501DT (L185)
dafe
BX2200 L1501DT
May 9, 2018
Near Melbourne, Australia
Hi everyone,
The oil light on my L1501DT comes on after running for about 10-15 minutes, and I'm not really sure what to do. The tractor runs or seems to run fine, but the lamp just stays on after this time.
Are there any pointers or tips for troubleshooting this? I changed the oil yesterday but didn't change the filter (wasn't thinking that far ahead, new to this whole thing...), no change with new oil although it sounds different ie a little smoother/happier.
There's a thread around here about opening up the engine and replacing a plug on the end of a cam shaft (and also a cool video on the tube), but my understanding of the symptoms of this is that the light goes off when revving.
Any tips or advice most appreciated! This forum has been a great help!
Oh, and what do you all do with your sump oil? Chuck it or some interesting uses? I remember sheds and kennels painted with the stuff when I was a kid.
Cheers,
Dave
4,546
First I verify the oil pressure with a gauge. The camshaft plug is usually an all or nothing issue. If it's in, then good oil pressure, out you have no oil pressure.
Issue could be a worn out oil sending unit. The oil sending unit is on the clutch side of the tractor (left) and screws into the block near the starter. Has 1 wire attached to it. Thread is BSTP. But you should be able to get adapters to screw in a 0-100 psi gauge into that spot from a good hardware store to get an actual reading. I believe the stock sending unit trips at 20 psi, but don't hold me to it.
Getting a good reading will tell you where to start looking. As the oil heats up, your oil pressure will drop.
1,003
You can start out with a replacement sending unit from Kubota to see if light stays out.
But adapting a gauge will give you the actual pressure so you know but be sure not to mess up the threads in the engine block, as mentioned they are NOT standard US pipe threads.
And I recycle my used oil since it is usually convenient to do so
2,170
Daren is correct - the oil plug in the cam shaft is a fatal flaw - however, usually oil pressure will hold when cold, then as it warms up the viscosity goes up- psi goes down tripping the sensor.
SO that is a place to check for sure, and if I am not mistaken the oil sending unit kicks out at about 7 psi. I have an engine that after it is worked extremely hard, has 14 psi at idle..... and 50 psi cold! (5w-40)
check that plug!;)
dafe
BX2200 L1501DT
May 9, 2018
Thanks everyone! I will get a gauge and see if I can get some readings. Once I get one, is it permanently attached to the sending unit?
I will have to be careful with the threads...
Yeah and I guess I can recycle the old oil :)
mattwithcats
774
65
The current sending unit is just an on/off switch, pressure rises, the switch opens, light goes out.
You want to temporarily replace it with one that can tell pressure.
Two kinds, the mechanical one use plastic or copper tubing,
The digital uses wires to the gauge.
Adapter 1-27 BSPT to 1-28 NPT
GlowShift 1/8 NPT Female to 1/8 BSPT Male Gauge Sensor Sender Thread Adapter Reducer https://www.amazon.com/dp/B00NWZ3TUI/ref=cm_sw_r_cp_tai_SAhpBbSCJ8NZS
Long term, if you put a ***8220;T***8221; in, you can have both the old on/off switch, and the new gauge...
The 1-27 BSPT oil pressure fitting size is also found on Subaru***8217;s,
LNA Auto Parts has a 10 centimeter hose with the ***8220;T***8221; on the end...
5,130
Since you're in OZ just get an oil pressure gauge that has BTPT fitting on it. ;)
dafe
BX2200 L1501DT
May 9, 2018
I think I found a gauge in the shed. Does this look right? There's no difference between an oil and a water gauge for example?
Had another read through of the operators manual, and it said not to worry if the oil light goes on under very low operating RPMs. Could be that I haven't been actually using it properly. I have just been experimenting with it, driving it up and down etc, so maybe that could be it :)
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
That will do the trick
I doubt it, but wait for the pressure readings.........
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
If you have a 1/4 to 1/8 reducer or tees etc., you can remove the oil pressure switch and place it in directly to get some readings, you don't need to permanently install.
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
I haven't checked, you will be able to on your machine. I'm just going off an early post with some thread sizes mentioned. I'd guess like previously mentioned you have dropped your cam plug. There is mention on this forum of someone replacing it by drilling a hole in the gear case and inserting a new one and putting a rubber plug in the hole. I don't remember what model it was done on. It saved them pulling the gear case etc.
dafe
BX2200 L1501DT
May 9, 2018
Thanks 100td. I was in town so posted in a hurry. Could I also check the oil pressure using the oil filter port? I will have a look tomorrow, nighttime here and the shed has no power.
