New tiller too big?
CrashMN
Arnprior, ON Can
I've been looking for a tiller for my B2620 for a while now but have not been able to find anything under $1000 so when I saw one for $600 I jumped on it.
The good; Sovema Italian made tiller in great condition, slip clutch is working and has a complete set of spare blades. The bad; it's a pig. 60" at just over 800lbs. Wanted smaller but...
I think the max for the 2620 is 50" and 675ish lbs. I don't have to worry about rocks or anything like that, I did 1800' of trench a few years back without hitting a single rock.
I'm pretty new to tractors so my question is this; Can I go slow and lower it down after a couple of passes or should I try and trade it in on a smaller one?
Is the weight my biggest concern?
Thanks for any thoughts.
Kingcreek
Grand L3010 GST 4wd, LA481FEL, various attachments and accessories
Aug 3, 2011
457
NW Illinois
its big for you but probably doable with multi passes.
even if you find a smaller one you won't lose anything on the one you got the great deal on.
hodge
Nov 19, 2010
2,854
367
Love, VA
I ran a 48" King Kutter behind my B7100. It did fine. I don't think that you will have problems powering a 5', but the poundage may force you to weight the front of the tractor, if you don't have a loader.
The 5 hp per foot of implement is a conservative estimate. My B7100 never ran out of power for the tiller, and I didn't make multiple passes to make it work. Our ground is semi-rocky, plus I tilled up a few new gardens, that hadn't been broken with a plow. 14 hp ran a tiller that should have needed 20.
BAP
Dec 31, 2012
2,532
671
You may not be able to lift it. You should be able to run it, but lift capacity may be a problem.
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
I had someone try to sell me a 72", if the price would have been better, I figured I could remove tines off one side until it was small enough to handle
Sent from my LGMS330 using Tapatalk
fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
303
129
Eastern PA, USA
I've been looking for a tiller as well but they're all $2000+. I'd jump on that for $600 without hesitation and find a way to make it work. If it bogs remove hte outer spline set from each side and just till a little less.
GreenMtns
B2601, 4' Frontier Rotory Mower, 5' King Kutter Finish Mower, 4' King Kutter Rot
Apr 13, 2017
9
Western Vermont
TractorData says your 2620 should lift "(Rear lift (at 24"/610mm): 1,058 lbs)" so you should be ok. But as was said, you will have to weight the front end to keep any hope of steering.
fatjay
Nov 12, 2016
303
129
Eastern PA, USA
Be aware it's probably a cat2 implement, while you have a cat1 hitch. I put a 3pt cat2 blade on the back of my b8200, and it lifted just fine, exactly 1" off the ground. I also have cat2 arms but my tractor is cat1. So that may be something to take into consideration.
WFM
L3800
Apr 5, 2013
1,192
503
Porter Maine
Toss it in your pickup , your not far from the NY USA boarder...meet me at the Vt boarder, I'll bring USA cash.
eipo
L4060
Dec 1, 2015
693
81
MI
I run a 60" on my 2650 with no problems. If the ground is to wet for tilling, it will bog a little. So I slow down.
Low range, 4wd locked in, it just eats. I just did both my neighbors gardens this evening. Tilled in some yard for them as well as they both wanted to expand. No issues.
I'm toying with reversing the tines.....
4,395
Fatjay, you sure you have cat. 2 on your B8200? Here's how most rear hitches are set up. I don't think a 19 HP tractor has a cat. 2 linkage, mine sure doesn't.
Each category of three-point hitch is designed for a specific range of tractor horsepower, according to the website Antique Tractors. Category 0, or category 1 if a 1-to-4 numbering system is used, is used on tractors of less than 20 horsepower. Category 1 is standard on tractors of 20-to-45 horsepower. Category 2 is used on tractors up to about 90 horsepower, and category 3 is generally used on tractors over 90 horsepower. Tractors with a horsepower on the border between categories can have either hitch depending on the manufacturer's design.
fatjay
Nov 12, 2016
303
129
Eastern PA, USA
I used the linkage off my 35hp tractor, because the pins for cat2 won't fit in cat1 holes. I wanted to use my blade behind my tractor in the snow with the blower on the front.
eipo
L4060
Dec 1, 2015
693
81
MI
Results of the 60" tiller on my 2650. This is a garden that we broke last year. This is the second year tilling this ground. It was lawn that I tilled in green.
Sent from a field
