Wildfire
I love the smell of fresh orange
Last week our local Kubota dealer delivered our new ZG 222 Z. This is the second machine we purchased from them in less than a year and I have to say it's because of the great service they have given us.
I got an opportunity to use the new mower and all I can say is WOW! It's only going to be used for my private use and I can do all my mowing in 1.5 hours on a regular ride on mower but with all the trees, shrubs and plants that's around the zero turn will make it easier and much more fun to do now.
I've added a few things to the mower to "dress" it up a bit such as a scoop on the engine hood. Some lettering and black trim around various parts of the machine. One thing that I felt it really needed was a rear bumper so seeing it was raining yesterday I decided to play in the shop.
I didn't realize it would take me 11 hours to build, paint and install the bumper but it's done now and I'm happy with it.
I designed the bumper so that would attach to the existing counter weight bolts. When I build anything I like to do it without altering the machine if possable. I also figured I would add a removable hitch although I doubt very much I will ever pull anything with it seeing I still have my Craftsman tractor and that tractor only pulls a small dump cart at times.
I started out with some thick wall 1 7/8 th OD pipe. Bent it and then put it in the bead blaster to remove the mill scale from it. I cut the area that would be the spot for the hitch tong. I figured I should machine and tap two spacers to weld into the pipe to prevent it from the possibility of collapsing if the bolts were put on to tight.
I capped the ends of the pipe and tig welded most of it but some areas were mig welded as well.
After I painted it and installed it I was very happy to see just how strong it is so the time spent wasn't wasted in my opinion. I attached lots of picture to bore you all with. Thanks again to Todd Fisher at Newfoundland Kubota for the outstanding service and a great machine.
