Need zerk size for the snowblower subframe
Jayhawk238
2004 L5030 HST/CAB
Oct 30, 2010
97
10
Featherville, ID, United States
I have the L2185A front mount snowblower the mid-pto sub-frame and drive line, but not a manual. I have several grease zerks that need replacing. Does anyone know the zerks size and if they are metric or standard threads?
WAS BANNED FOR NSFW PICS
5,143
Considering that the snowblower is manufactured in Canada, I would be inclined to believe that they are metric. I suggest taking one out and going to NAPA where they have a good selection of both SAE and Metric grease fittings. This is what I did when I needed just one or two. If I were to need a lot, then I would purchase an assortment like this
ZELCAN 230pc SAE & Metric Grease Fittings Kit Hydraulic Grease Zerk Assortment: 1/4" 1/8" M6 M10 Straight 45 90 Degree Zerks Galvanized Steel Set for Replacing Missing or Broken Zerk Grease Fittings From Amazon for $29.99 with free shipping. This is what I would call a lifetime assortment.
mtdave
L4060HSTC
Jan 3, 2022
23
Might want to check the Messicks diagrams, they typically show similar info to what's in the manual. My L4479 has 1/4" Zerks and a mix of Imperial and Metric Hardware otherwise. A quick look at the L2185 doesn't show individual grease fittings, so I assume they're part of the pillow blocks, which on Messicks site show as "inch" size, so I suspect a Inch Zerk as well. Hope this helps.
5,544
yeah, 230 piece kit and guess what size is NOT included ???;)
BTW lots of stuff 'Made in Canada' is NOT Metric !!!
Even though we went 'metric' under the 1st Trudope, for say highway speed signs and distances whenever the cops say 'be on the lookout for this bad guy..... six foot two inches, weighs 210 pounds......
