need advice on a light duty scraper for my B7100
Kneedeepinit
B7001
Oct 4, 2015
Calgary, Alberta
I have to level part of my acreage to build a garage. Not a huge area but the cost to get someone in would be about the same as buying an attachment for my B7100. I checked local used options but have not found a box scraper for a compact tractor like mine.
I did find a light duty 3-Point Hitch 5 ft Box Scraper at Princess Auto. It weighs only 462 pounds and has a max hp duty of 45 which is far greater than the 19 I have. I would think the rototiller is similar weight so the tractor can handle the weight of the scraper .
I was looking for a 4 foot wide one but they only sell this one. My questions are
1) is this too big or can common sense operation be sufficient?
2) what category 3 point hitch do I have? I assume it is a category 1. I currently have a 4 foot rototiller installed.
2,210
Kneedeepinit
B7001
Oct 4, 2015
Calgary, Alberta
That looks like a better fit. Northern Tool is not close to me but thank you for the model and make. It gave me something to look for. I am going to look for that scraper in Montana. Our acreage is very close to the US border and it is easy for me to go there to shop
Jchonline
598
Red Feather Lakes, CO
A few thoughts and questions:
What is the weather like where you are? My ground is already frozen, so dirt work has come to a standstill. Second, is this a simple grade, or do you need to really move dirt around (ie get rid of hills, etc)? A 4 ft BB is going to take a long time if there is a lot of displacement.
Bmbbm
Bx2370 land pride box blade 60"mmm kubota fel
May 29, 2016
282
Chillicothe mo
Does Tractor Supply operate in Montana? They carry their own store brand BoxBlade. I have a 4foot Land Pride that you can purchase from your Kubota Dealer. I'm well satisfied with it. I too would recommend staying with a 4 footer.
Kneedeepinit
B7001
Oct 4, 2015
Calgary, Alberta
Thank you for the help. There is a tractor supply close enough to me l.
I have signed up for their email and can wait till they go on sale. I won't be starting until next spring so time m is my friend
Simple grade job, I have a gradual slope that I have level off for a garage. There are a few bumps on my acreage as well that could use some dressing so a box scraper is something I can use. I also have a 200 foot driveway that will need periodic maintenance so.
5,279
Check out North 40 for implements. ;)
2,241
The factory blade for the B7100 was 42" wide. It will handle a 48", but I wouldn't go an inch bigger.
