My Truck And Trailer. Show Yours!
ranger danger
Kubota M6060, MEB 802A tactically quiet generator
Jun 11, 2017
310
293
East of Placerville Ca
2019 Ram 2500 diesel
20k gooseneck trailer 20+5
Kubota M6060 w/ loader
EA 60" grapple
EA 60" forest rake
Titan forklift
Titan post/tree puller
United 72" box scraper
Man lift
The truck is in a small ditch. It actually sits level. I bought the trailer used. The guy under the rear is reclocking the wheels which were put on wrong.
3,640
Truck:
2017 Tundra
Sumo springs
Stock P rated tires swapped for 10ply rated light truck tires
(Also pull a 9k camper so that stuff was on there pre-flatbed.)
Trailer:
35 year old local shop built, 16’ deck, twin Dexter 7,200lb axles.
Tractor/Implements:
L4701
Land Pride BB1572 box blade
Tar River grapple
42” forks
Woodland Mills WC-68 chipper
IMD 16kW generator
Titan Attachments 72” pine straw rake
Howse 500 rotary cutter
Leinbach 72” backblade
Leinbach PTO drive auger
Single gang disc harrow that’s needed new discs for going on 40 years
Two share 16” moldboard plow
Trailer mover
Ford pond scoop
3 tine subsoiler
Maybe forgetting some old stuff we don’t really use
Trailer was titled to my father. He used it for about a year 35 years ago and then parked it in his shed where it sat motionless for the next 34 years. He decided it was time to either get it usable or sell it to free up the bay in the shed. In exchange for the title, I went through the wiring and brakes to get them working right, changed the wiring harness plug from a 4 wire flat + 5 wire flat to a standard RV plug, added breakaway kit, swapped the 3/16” safety chains for chains rated for a 14k trailer, replaced tires, removed cleaned repacked bearings, added conspicuity tape, put a license plate on it. I have about $750 in it. Don’t use it much but have used it several times to move the tractor. Dad lives next door and can still use it whenever he wants.
First pic is pre-rehab. Put the tractor on it to make sure it fit and balanced right before any $ or sweat invested. If all four trailer tires had exploded just sitting there, I would not have been shocked. Did NOT tow that anywhere.
Post rehab. Paint still original. Tires looking a little better.
Had the dealer install rear remotes. Picked it up at lunch so it was “bring your tractor to work day” at the office. It tows and stops quite nicely.
Hunters gun
“My gun collection is bigger than your gun collection”
Oct 18, 2021
61
35
PA
Yup! And a few other states, too!
ranger danger
Jun 11, 2017
310
293
WOW!!! Lots of great setups out there! Keep'em coming!
My trailer was a distress sale. The guy found out his wife was cheating on him and embezzling from his company. The trailer needed a new deck and spare tire. Otherwise it was in great shape for $7000. Sometimes you find a nut, sometimes a nut finds you!
hodge
Nov 19, 2010
2,860
371
Love, VA
2004 F350, 42,000 miles, V10/6 speed.
1badDart
109
107
W. KY.
My 14 Ram 1500 with my 18' goose neck that I haul the hot rod on. The trailer has 5200# axles with brakes on both axles.
rc51stierhoff
B2650, MX6000, (BX sold)
2,233
Good day. I have a diamond c. I will leave outside at a 2nd property part of time so went with it over a PJ because of the paint. Folding ramps are absolutely awesome. Get as many tool boxes as you can and a step is helpful. If you plan to load from side of trailer a deck over is the way to go in my opinion for my application. Maybe also consider all you want to haul at one time and how much space you need to properly load and secure. If you ever plan to rent something bigger GVWR for other use is helpful to think about now. Until you have a tire failure you really can’t appreciate a tandem axle. Happy shopping.
rc51stierhoff
2,233
RichardAaronlx2610
Aug 3, 2021
426
476
New Jersey
My old a$$ suburban with my Lx2610 and my trailer that needs to be longer. They both do the job and I’m too cheap to buy a new car 😂
4,261
I think most state police will say the BH must be chained down on the deck.
RichardAaronlx2610
Aug 3, 2021
426
476
New Jersey
One of the most argued things in all the land. Here in Jersey you have a better chance of getting pulled over for having no front tag than you do for having an improperly rigged machine. Most people that put machines in dump trailers don’t even chain them down lol. But if I was at work I’d never haul on the lowboy without chaining the boom down
rc51stierhoff
2,233
I am not really sure. My understanding was that if under 10k and the arm is locked it is acceptable. But I am not sure and I am not the one writing tickets. I posted a link on another thread with Indiana state. It had some helpful info.
RichardAaronlx2610
Aug 3, 2021
426
476
New Jersey
id love to see the actual laws. I’ve searched before with no luck. Maybe i iust Suck or wasn’t patient enough
