Mower Deck Undercoating
4,073
Looking for suggestions for the underside of my ZTR mower deck. I pressure-washed it today and most of the original factory paint is long lost.
jyoutz
Jan 14, 2019
2,585
1,678
Edgewood, New Mexico
Could you use some of the truck bed liner paint? Obviously not the products with the rough texture. Or simply cleaning, then paint a thin coating of oil prior to storing the mower? Or maybe a hardened epoxy paint coating?
BAP
Dec 31, 2012
2,567
694
I use rust converter. It turns black and bonds quite well.
4,372
"Hardened epoxy paint" would be best, but I might also consider Fluid Film.
lynnmor
B2601-1
May 3, 2021
1,349
1,055
Red Lion
I use Fluid Film for its rust prevention, not to keep the deck free from buildup. There is absolutely nothing left of it after each mowing. I use a Country Clipper zero turn with a standup deck and clean it completely after each 2.5 acre mowing, the last time there was at least 3 gallons of buildup despite the coating. No, the grass was dry and the mowing was done in the afternoon so there was no dew.
4,073
Would you use the Fluid Film over raw steel? A lot of the original paint is worn away on the underside of the mower deck.
2001TLB
L48TLB, 60" EA SSQA Root Rake Grapple, EA SSQA Fork lift
Nov 14, 2021
46
45
Shelton, Washington
You might be able to find some orange paint on the underside of my mower deck, but not much. I pressure wash the underside after the season and let it dry. I empty a full can of Fluid Film on it. During the season, I blow out the underside after each 2.5 hour mowing. It is a little easier with the feature that allows me to flip the deck up for better access. I used the same procedure on prior mowers and it seems to work pretty well.
Doug
Bearcatrp
BX1880
Mar 28, 2023
435
221
Minnesota
Anyone try silicone spray? When I had my cub cadet with bagger, used to spray the tube to help prevent clogging.
2001TLB
Nov 14, 2021
46
45
Shelton, Washington
One can of Fluid Film in one application? You ought to buy in by the gallon then, much cheaper!!
I have thought about buying it that way. But, since I only apply it after the season, it's not too big of a deal.
Doug
4,244
if you want to paint the underside
remove deck, remove everything to the bare shell, sandblast, use 'aircraft' grade epoxy,FOLLOW the directions to a 'T'. It'll last 12-14 years minimum.
