Seanbarr,
Point is well taken. My small ford does not have an implement on the FEL, just a snow blower on 3 point, easier to maneuver tight spaces w/o bucket.
QA remove and reinstall should be easy as advertised but that isn't always the case. My tabs will not always stay under the lip of the bucket when connecting.
I usually need to employ a short ratchet strap to maintain tension till connected.
But the garbage needs to get to the road for p/u and winter can present a challenge. Some have very long and angled driveways.
Wish all the inventors luck in devising a method to ease the task. My snow pusher has two hooks on the top.
In the past I looped a small chain around the belly of the tote, and attached chain to the hooks.I
A narrow vertical flat plate welded to a clamp on adapter to bottom bucket lip should work ??
