It's been so wet that my grass has gotten too long (5-7") and lays over flat on the ground. Once it finally dried out, I fired up the 2370/60" deck and started to mow, thinking the stock blades (21.5" long, 7/8" bolt hole) had enough lift to pick it up and slice if off. I was mistaken. Bumping the throttle to 2,800 didn't help, neither did wide open. Faster/slower ground speed did not make a difference.
Mower height is set to 3", anti scalp wheels in the third hole from the top. Blades sharp, mower deck operating normally, side discharge, no mulching cover, flat ground. Been cutting with Kubotas for 6 years and never had this issue till now. My stock blades aren't cutting it, literally. Are there other factory or aftermarket blade sets out there that are better than the stock ones? Maybe some with more/better lift? Recommendations? Vendors? Or is this something else entirely, what am I missing here?
