Butch
I think I initially posted this in the wrong place ... so here we go once again....
OK All.... her is the 64 thousand dollar question.... Does anyone have any recommendation for preventive maintenance on the Kubota mid mount mower gear boxes other than just checking the oil level every 10 hours.
From what I have read my issues with literally blowing the bevel gears to shreds... is a common problem after around a 1000 hours. Also... once you hear the metallic gear box whine... may as well get your wife's credit card out... This is what I did... hehehe !
First...I was surprised to see there were no thrust bearings on the vertical blade shaft... just a regular ball bearing.
Do any of you all ever pull the box and change out the output shaft oil seal BEFORE it leaks?
Let's say we wanted to rebuild the gear box with new bearings and seals and REUSE the bevel gears. How do you use the shims to set the backlash?
My new gear box is working great!
