M5660SU Advice
2,543
677
Congratulations, that should be a good solid tractor for your bush hogging work.
SDT
multiple and various
Apr 15, 2018
3,087
928
SE, IN
I just purchased a Kubota M7060HD12 ROPS. I ordered it with an extra set of hydraulic valves, front end loader, cast wheel weights with the wider tires and liquid ballast. The total out the door was $39K. I hoping this will be enough tractor for me to use a 84" rotary cutter in some fairly thick brush/sapplings. I looked at going with a smaller tractor but when looking at prices, it only made sense for me to go bigger.
Your 7060 should be sufficient for a medium duty 7' cutter in most conditions so long as you do not get carried away with speed. Trees are another matter.
A bit of advise.
If your cutter has front chains, replace them with rubber belting once the heavy clearing is done. Belting is much more effective in keeping debris off of the back of the tractor and operator than are chains.
Make sure that the mower slip clutch is adjusted for the PTO HP of your tractor and is not frozen (common). If it is frozen or adjusted too tightly, you have little or no protection for the internal components of your tractor.
It is easy to puncture tires when cutting saplings. If you do, you will loose your liquid ballast and create a mess. Dull blades are best for saplings because they tend to not cut the saplings off clean.
Unlike, most, I keep the blades on all of my rotary cutters sharp but do keep a spare set of dull blades for saplings.
SDT
cavjock23
M6060,709 pull shredder, offset disk, Pallet forks, Box Blade
Apr 9, 2017
47
Houston, TX
You will love the M6060..
I pulled a 7 footer pull style with no problems. (it’s for sale if your interested)
Now pulling a 10 footer bushhog. It did bog down in hood high grass going about 4.5 MPH, but normally i’m shredding weeds and brush. It handles my normal stuff very easily. Can’t go wrong with the 6060..
AJared
36
Medon, TN
I really appreciate the advice. I ended up purchasing the M7060. It will be delivered next week. You all got me at the "No one ever said, I wish I had less power."
SDT
Apr 15, 2018
3,087
928
SE, IN
Horse power is like money and, for a young man, at least, women.
Some's good and more's better.
I expect that you will be pleased with your decision.
SDT
