M Series 3 Point Drifts Down
doctormdds
M7040
Jul 27, 2013
DeRidder, LA
My 2007 Kubota M7040 is having 3 point problems. With the tractor running, I can lift an implement with the 3 point and it will gradually begin to drift down. After it drops to a certain point, the hydraulic system will pick it up again. This happens over and over again. If I close the flow control valve (the little round know on the floor which adjusts how fast an implement will fall) it will hold but then I can't let the implement down. Fluid level is good. Any help you can give me will be appreciated.
8,285
It sounds like a feed back lever is out of adjustment.
I have the service manual if you would like a copy of it.
Just send me a PM with a Email address and I'll send it over.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,221
142
Coyote Flats,Texas
The problem you describe is called hyd hiccuping. Sounds as if rockshaft seal(internal piston or external cylinder) or control valve is leaking and when enough oil is lost then 3 pt corrects it's height.
doctormdds
M7040
Jul 27, 2013
DeRidder, LA
What is a rockshaft seal or control valve? How do I fix these? While I'm mechanically inclined, I've never owned a tractor until I bought this one new in 2007!
8,285
Your tractor has 2 external cylinders, so you wouldn't have a problem with internal piston leaks, you could pull the 2 vent tubes off of the top of the 2 lift cylinders and see if it's leaking past the seals on your lift cylinders.
I'll be sending you the manual then I can point you to the right pages and pictures.
Umizedme
Kubota b7800 with FEL, 5’ brush hog, 50” tiller, box blade, and scraper blade
Apr 8, 2023
Oklahoma, USA
I know this is an old thread, but I too am experiencing this problem on my b7800 with approximately 800 hrs.
Any help will be greatly appreciated!
Zimcocomp
L2550, FEL, Hoe, snow plow, Bolens QT17-FEL
Sep 13, 2011
21
West Newfield, ME
This sounds similar to my problem except mine happens in faster cycles. Also was grading our road today and noticed the FEL drops a little when the 3 point is bouncing. I graded our road by mainly using the hydraulic top link for height adjustment. Not too bad for an 80 year old. Thanks for your suggestion about adjusting the feed back rod, only I can't loosen the inner nut to even start. Is there a special tool to reach it? Thanks for your help.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,084
1,692
WestTn/NoMs
If it stays up with the lowering speed knob closed, the cylinder seal is not likely the problem.
4,827
Good thinking - I forgot about the lowering speed valve.
CORROLLARY
If it drops with the engine off and valve closed it is likely the cylinder seal.
