LX3310 Error Code Reset
S-G-R
LX3310
Jun 17, 2020
1,189
2,502
PEI Canada
What is the number? There was a recall on the LX3310's MSC-2022-001. Have you had that done?
AllPawDrive
Aroostook County, Maine
The recall addresses Error code P0089. That is not the error code I have.
I have addressed the issue related to my error code and now it’s time for a reset.
Does anyone know how to reset an error code on an LX3310?
SDT
multiple and various
Apr 15, 2018
3,269
1,063
SE, IN
I believe proprietary dealer software is required to do so.
lugbolt
ZG127S-54
Oct 15, 2015
5,404
2,097
Mid, South, USA
you can't remove codes from the ecu without the software.
you might be able to remove it from the panel but it'll still be stored in the ecu
AllPawDrive
CODE CLEARING INSTRUCTIONS - LX3310
5.1.3 Clearing error information (mode b)
(LX3310)
In this mode, displayed error information on the meter
panel can be cleared.
NOTE
• Be sure to clear error information by performing
this procedure after servicing.
1. While holding down both DPF inhibit switch (2) and
parked regeneration switch (1), turn main switch to
“ON” or “START” position.
Mode selection display is indicated on the LCD (3).
2. Press the parked regeneration switch (1), which will
change the mode indicated on LCD.
3. If is indicated on LCD, press the parked
regeneration switch (1) for more than 2 seconds.
Error information clear mode is selected and the
expression [PUSH] is displayed (A).
4. Press the parked regeneration switch (1) for more
than 2 seconds.
The expression [OFF] is displayed.
5. Turn “OFF” the main switch.
6. If clearing fails, repeat from step 1.
whitetiger
Nov 20, 2011
3,076
1,517
Kansas City, KS
That will only remove the code from the tractor's display, the tractor has to be connected to Diagmaster which is the only way to clear the error code from the ECU.
