DepositGuy
Kubota L5030 with cab, 6 foot Landpride Rotary Mower, Kioti LK3054, too many att
About three options occur to me:
1) Richie Rich - Buy a new casting and spend a couple days swapping it out, done forever.
2) Farmer Joe/Fabber Fred - Grind off the old stuff and fab your own ears (use mild steel, flesh won’t work) and bolt them on, might or might not work for a while.
3) Welder Wes - Grind off all the old stuff. Consult with someone with skill and equipment to weld cast iron and fab some ears out of what they suggest and get it all welded up, could work, probably for a while.
I suspect the BH hooks up to these ears as well? If so, I’d probably go with option 1. But if you have more time than money, options 2 and 3 might work, but I doubt option 3 is significantly less expensive than option 1 if you outsource.
If it was the ‘70s, Dad would have (did) employed option 3 on the 8N, but he’d weld it himself. Called it brazing and he’d heat the casting first. Had some sort of powdered flux to dump on it too IIRC.
Good luck with it. It looks like a decent enough challenge.
