Long time no see, but i made a new land plane
L1802dt
L1802dt
Mar 17, 2018
31
Arnhem
Long time no see, but i made a new land plane. Took my a while to finish it. Project set stil for about half a year... Hope to get some feedback from you guys.
Next project landscaping rake :)
Verzonden vanaf mijn iPad met Tapatalk
Bmbbm
Bx2370 land pride box blade 60"mmm kubota fel
May 29, 2016
282
Chillicothe mo
Looks really Good. Looks like it does a good job also. Wish I had that skill set.
Stmar
B2650HSDC
May 23, 2017
906
42
Buffalo, Wyoming
Do you put any weight on it? My drag is an old harrow without the spikes and a cutting edge from a grader blade mounted on the back end of the harrow frame.
Very nice job, looks good.
L1802dt
L1802dt
Mar 17, 2018
31
Arnhem
No weights on it. For the purpose that i am using it for i don’t think it really needs weights. I use it in the woods to level sand and dirt roads so i am a bit scared to get stuck on a root. Still in the testing fase :)
L1802dt
L1802dt
Mar 17, 2018
31
Arnhem
You really do not need a lot. Dril, grinder, simple welder and the will to push trough. I’m not trained by any means. Just go for it.
4,081
That design is horrible!
You need to ship it to me across the "pond," and I will make the necessary modifications.
I will return the much better implement back to you. No charge for my work, but you pay shipping to/from.
Just joking with you...it was my attempt to get to use it! Looks like it does a great job, and you did a great job building it!
My only observation, and I have never used one, is that you often see the cross-members at a slight angle. Don't know the purpose.
Good for you!:cool:
5,199
The only thing I would do is add a support across the whole unit to keep the blades from getting bent also give you a triangulation pint to tie in the center mount, other wise looks great!
5,199
You don't need weight on a land plane, the angle of the blades will do the digging till the skis hit. ;)
L1802dt
L1802dt
Mar 17, 2018
31
Arnhem
Very nice job! Where did you get the blades?
To be honest... they are not real hardend steel blades. Just 2mm thick mild steel plates. Gettting proper blades... nah... One blade would be more than 80 euros. 3 mild steel strips is under 15 euros. So I made two extra sets. I will only use this land plane in the woods on sand and dirt roads. So i think these will keep in shape for a long time :)
bearbait
Dec 9, 2011
4,015
773
New Glasgow Canada
Sounds good to me, nothing wrong with saving a few bucks.
