Ok sum ting is wong here or at least some here are convinced sum ting is wong here.
So what is wong ?
So what is wong ?
Congratulations you win a cigar !!!!!Actually, when FWA or Front Wheel Assist first became a popular option on tractors, some manufacturers use to recommend turning the front wheels around so they were backwards to increase traction backing up in muddy conditions when loading things like manure spreaders in the field.
Yes it would cause a lot of strain on the front end having the rims dished out!I feel like every Kubota of that vintage that I've seen has had the "bowl facing in" on the front tires.
Does having them one way or the other have the same effects as wheel spacers on a car? With wheel spacers and back spacing can come unnecessary hub bearing wear.
