The loader settles, even when empty, while the tractor is operating. There are no obvious leaks from the cylinders. Is there a way to tell if the problem is the control valve?
Can the valve be rebuilt, or is there a replacement available...the loader is a B219 from 1977, valve is 2 spool, 800psi. I don't know what the flow is from the front pto mounted pump.
thanks
thanks
