Hi Guys,
I wanted to see if someone could help me. I have a Kubota Grand L 6060 50th anniversary. I want to purchase a limbsaw circular hydraulic saw. It says it requires 10gpm flow but mine is at 9.4gpm. I will not be steering while cutting. I also have a 3rd function as well. My question is, do I have enough juice to run this saw on an 8ft boom arm? Should I be concerned with heat? I posted the link below for anyone that wants to see exactly what I am purchasing. Thanks in advance for any information you guys can give.
LimbSaw Hydraulic Circular Saw - Standard Boom
The LSC Circular Saw mounts directly to a tractor's front-end loader enabling you to trim overgrowth from the comfort and safety of your tractor seat. Operates with a 10 GPM flow rate, requiring your tractor to have a 15 GPM Uses a 16 5/16” carbide-tip blade with a tip speed of over 11,000 RPMs...
limbsaw.com
