LEDs for BX head lights
Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
Dec 25, 2010
953
Kellogg, Idaho
2,843
Thanks Cat now I have to clean the screen again :D
Thanks winzder ,I will give them a lookie see
windzer
Bx2370-1
Dec 8, 2015
82
Illinois usa
They r just as bright if not brighter than stock plus they ain't the ugly yellow color when they're on I also have a 14 inch 2000 lumen light bar on the top of my rops so I had to get led headlights to match that lol also i couldn't believe the amount of power the stock ones used whenever I had the tractor running and I flipped the headlights on I could hear the engine rpms drop then come back up but with the led installed you don't get that
windzer
Bx2370-1
Dec 8, 2015
82
Illinois usa
Another thing your factory bulbs are going to be a 896 model bulb the 881 replaces that number if you look under the specs on that link I posted you can see all the number bulbs this 881 bulb replaces
OC455
BX2350 LED ROP, FEL, Belly mower,modified snow blower, pole boom, middle plow
Sep 30, 2016
161
12
Rome NY USA
Be careful of some of the LED replacement 896/881 bulbs. I found a 10w LED replacement. They're bright, but the small lens at the front didn't stay on and now that small lens is bouncing around in the headlight housing.
Going to find a better one.
