My new L6060 works great. However, on a recent cold morning, I turned to ignition key to ON until the glow plug indicator went out, then started the engine. The Master System Warning Indicator (MSWI) starting flashing and did not go out. I restarted the engine and the MSWI did not turn ON again. After playing around with this I learned that anytime I pause a couple of seconds before cranking the engine, the MSWI always turns ON. If I just turn the key and start the engine, the MSWI does not turn ON. I researched this a little and some say ignore it (NOT), and others say that the incorrect HD alternator has been installed. When I start the engine, no additional electrical loads are on (i.e. lights, widow defogger, etc.). Anybody else seen this problem? Solutions?
