Well just got the old bota out for winter work and noticed my bucket problem is back with a vengeance. I went through everything I did last year with no change, I must have been on unlevel ground when I thought it was fixed……….or drunk maybe.
I will try to keep my explanation as short as possible and apologies for incorrect terms. I am convinced the boom is tweaked at the cross tube, I removed the bucket and let the arms down and the right arm hits the ground first. I removed the backhoe and brackets for a better view of loader attachments.
One of the first things I notices was the vertical mounts mid tractor were not at the same angle, off about two degrees. Found a crack where the horizontal arm to the rear axle connects to the round tube of the vertical mount. The crack had pulled apart and the vertical part that holds the boom pins had twisted away from the correct angle. Unfortunately pulling that back together and getting the uprights at the same degree of angle made things worse, now have a 3”difference with the bucket.
After looking at everything this makes since. It appears as if someone put way to much down pressure on the left side of the bucket causing everything to tweak. One might think just stress the other side in the same manner but I don’t think that is the answer, concerned about damaging something else or braking mounting bolts and such. None the less the problem must be solved and I cannot afford a new loader.
Being a welder here is my solution. I am going to use a dial indicator in different locations and lightly stress the boom in the direction it needs to be tweaked. It seems that where the dial indicator has the most deflection would be the place to heat with a rosebud and attempt to realign. I fully understand that even if this works it will weaken the area that is heated and make it brittle, but it is worthless right now. The only way I will be able to clear snow is let air out of the back tires so it self levels under a load.
I am going out now to do my dial indicator experiment and will report my finding (if any) before I go after it with a torch.
Input, ideas, warnings………..anyone?
