Engine Block Heater Location
Localisation pour les chauffes moteur
MODEL / MODÈLE BLOCK HEATER PART # ENGINE / MOTEUR LOCATION ON UNIT
POSITION SUR LA MACHINE COMMENTS
COMMENTAIRES
TURF
GR2100 *70000-00117A D782 Tractor frame KCL local kit including 7000092500 block heater kit
GR2110 *70000-00117A D782 Tractor frame
G2160 *70000-00117 D782 Tractor frame
BX1850 *70000-00117A D722 Heater block attached to muffler bracket. KCL local kit including 7000092500 block heater kit. Easy access. No cord length issue
BX2350 70000-000771 D902 25 mm frost plug in the engine block No issue
BX24 70000-000771 D902 25 mm frost plug in the engine block No issue
BX25 70000-000771 D902 25 mm frost plug in the engine block No issue
BX2660 7000091510 D1005E3BX Exhaust side threaded plug No issue
GF1800 70000-17552 D722 Rear of cylinder head No issue
F2680E 70000-91510 D1105 Exhaust side threaded plug No issue
F2880 70000-91510 D1105 Exhaust side threaded plug No issue
F3080 70000-91510 D1305 Exhaust side threaded plug No issue
F3680 70000-91510 V1505 Exhaust side threaded plug No issue
ZD321 Not available D782 Tier 2 Not available ( no space at the back of cylinder head) to fit the 70000-73595 25 mm frost plug. Model not offer for 2007
ZD326 70000-91510 D1005 Exhaust side threaded plug No issue
ZD331 70000-91510 D1305 Exhaust side threaded plug No issue
B
B7510 70000-91510 D1005 Exhaust side threaded plug No issue
B7610 70000-91510 D1105 Exhaust side threaded plug No issue
B7800 70000-91510 V1505 Exhaust side threaded plug No issue
B2320 70000-91510 D1005 Exhaust side threaded plug No issue
B2620 70000-91510 D1105 Exhaust side threaded plug No issue
B2920 70000-91510 D1305 Exhaust side threaded plug No issue
B2630 70000-91510 D1105 Exhaust side threaded plug No issue
B3030 70000-91510 V1505 Exhaust side threaded plug No issue
L
L2800 70000-92500 D1403 Left Side, 1st/2nd Frost Plug from the fan No issue
L3400 70000-92500 D1703 Left Side, 1st/2nd Frost Plug from the fan No issue
L3700 70000-92500 D1803-M-E3 Knock-in type Left Side, 1st/2nd Frost Plug No issue
L4400 70000-92500 V2203 Knock-in type, need to R hydraulic pump No issue
L3240 70000-92500 D1703 Left Side, 1st/2nd Frost Plug, Can also use 70000-81500 in line block heater. No issue
L3540 70000-92500 D1803 Left Side, 1st/2nd Frost Plug, Can also use 70000-81500 in line block heater. No issue
L3940 70000-92500 V2003 Right Side, Behind Hyd. Pump, need to R hydraulic pump. Can also use 70000-81500 in line block heater, Lower Rad. Hose, left side No issue
L4240 70000-92500 V2203 Right Side, Behind Hyd. Pump, need to R hydraulic pump. Can also use 70000-81500 in line block heater, Lower Rad. Hose, left side No issue
L4740
L5040
L5240
L5740 70000-92500 V2403 Right Side, Behind Hyd. Pump, need to R hydraulic pump. Can also use 70000-81500 in line block heater, Lower Rad. Hose, left side No issue
M
MX5000 70000-92500 V2403 Knock-in type, need to R hydraulic pump,
MX4700/MX5100
M5640SU 70000-92500 V2403 Knock-in type, need to R hydraulic pump,
