L3800HST PTO cable adjustment
5,133
The WSM has the procedure in it, I don't have a copy of that one so I can tell you.
There isn't a cheap or free version available, you'll have to get it from a dealer.
Jim L.
815
88
Howdy
Linkage diagram on page 3-M2 of WSM; adjust procedure on page 3-S16.
Back by the PTO handle, center the cable on the metal bracket using the two nuts.
Place the PTO handle in the OFF position.
Other end of PTO cable, at case. Back off the nut closest to the cable. Then turn the same nut the opposite way to tighten until just before the case lever starts to move.
Then tighten the nut on the other side of the case bracket and should be good to go.
De nada.
