After purchasing a used L3750 4WD tractor with loader, I discovered the hydraulics moved VERY slowly. By the way, it has a hydraulic shuttle shift if that matters. I drained the fluids, and replaced fluid and hydrualic spin-on filter. No change...VERY slow loader and 3point. Kubota dealer says it needs a new pump. $1,000 later I install new pump......SAME PROBLEM. Now he says remove sheet metal (fenders and fuel tank) and lift the top off of the 3point hydraulic section to check the valve inside the tractor. Removed it and all subsequent appendages to check for crud and wear. I didn't find anything unusual. I'm afraid to go to the bother of putting it all back together in the event I'm missing something. The dealer also mentioned checking the 2" or so rubber line going from the suction side to the filter for small holes. Any other suggestions? This is APPARENTLY A PROBLEM FOR SOME L3750'S AS I GOOGLED IT AND FOUND SEVERAL EXAMPLES OF THE SAME PROBLEM, BUT AS OF YET HAVEN'T HAD ANYONE RETURN AN EMAIL REPLY WITH THEIR FIX!
THANKS FOR ANY HELP PROVIDED!
JOHN MILLER
JOHN MILLER
