I could not find a discussion on this so I'll start a thread to ask my questions. I'm sure there are a lot of experts here who have good suggestions.
A little background, a couple of years ago I left the tractor out more than usual (usually in my garage) and the clutch disk stuck to the flywheel. I limped along using the hyd clutch and eventually the disk popped loose and I continued to use as normal but the clutch pedal needed to be depressed all the way to disengage the clutch. So I attempted to adjusts but the turnbuckle was maxed out as short as I could make it. Then last summer the clutch got worse and I could only get partial disengagement. Put it up for the winter and tackled it this spring. I have the tractor split and have a new clutch kit. When I took it apart I noticed the clips that hold the throughout bearing were in the bottom of the housing. I thought the new kit would come with the clips but it did not. The clutch pressure plate and disk do not look bad to me but I will replace.
I suspect the failure occurred because the clips were not holding. I have never seen such a weak design using these little wire clips to hold the fork to the bearing carrier. I am tempted to add some SS wire. Has anyone done anything to make this a bit more robust. It's a real PIA to split the tractor. Any advice here would be appreciated. Thanks Dan
